Ct90 2 stroke
G.W
Nyssa Oregon
As you might know I have a 1969 honda ct90 project that is a long term project. I decided I wanted a 2 stroke in it so I started researching engines. I found a relatively small motor that would be grate for the HP and speed that I want (about 65mph top end and 55 reliably) if I gear the bike right it should do this just fine.
I ordered an engine 2 weeks ago and it finally arrived yesterday. I took it out this morning and fount the top mount will work if I trim the transmission fill and route a hose to it. The bottom mount I will have to build a secondary cradle for. The engine is in better shape than I expected. It still needs rebuilding.
The engine is from a 1979 suzuki ts125.
Denny, the grumpy old man strikes again!
Good work, I know you’re going to be moving quickly without a bike to ride for now.
  • Haha
Reactions: G.W
