It's not exactly a new issue, I'm just out of ideas how to stop it without welding some sort of stop rail along the engine base to keep it square.
Basically my 208 makes enough power that if I really crawl the throttle the cylinder head slowly pivots to the right side where the chain is attempting to draw the wheel and engine together. I have cranked bolts as tight as I dare, being grade 8 if I go any tighter I'm concerned something is going to snap.
The only bolt that seems to never move is the only one not grade 8 or even grade 5, it's just a crummy old carriage bolt fed from underneath and nutted top side. The only reason I say it seems to never move is it is in the left leading corner (transmission side, under the starter motor)
I just haven't had the chance to swap all of them for carriage bolts to see if the theory tracks at all about the head surface area being what's "holding it better" or if it's simply the least leveraged bolt of the 4 given the nature of what is causing the engine to rotate slightly.
It's only enough that I'm sure it's probably not good for the chain, but it's not going loose or derailing either. All visible factors say chainline is dead on between sprockets too.
