Clean solar panels smell like NOx and gasoline.
Seems ironic...
Increased compression, non-emissions Honda style carb #98 jet, cyclone air cleaner with cover off, ethanol free pump gas (no canned shtt here).
Probably do go-kart style air cleaner, since it's a pressure washer and doesn't make or kick up much dust. Probably try messing with advancing the timing. And make a real exhaust.
The installed cyclone air cleaner cover is choking the engine at high speed.
Must be doing something right, it's keeping a heat range #6 plug nice and clean, it used to foul out #6 heat range ngk, champion #11 plugs, ect. Had to use at least a 5.
Seems ironic...
