Shop Our Other Brake Parts
Shop All Our Parts
Mini Bike Brake
Drum Brake for Mini Bike and Mini Chopper
This brake works with a sprocket/brake hub combination. The 4 1/2in. internal expanding brake fits inside the hub and expands to provide great stopping power.
Will fit with sprockets #1322 and #13632.
There is a built in anchor, two cable mounting ears, and premium bonded lining.
The actuating arm is long. 5/8in. bore.
110% Lowest Price Guaranteed!
This can also be used for go karts. This design saves room because it combines the sprocket with the brake drum.
A drum brake is a good choice for any project because it is shield from water and oil more so than a disc brake or a band brake. The drum brake fits inside the sprocket/drum combo and provides quick braking power.
