go kart plans
DIY Go Karts
Buy Great Go Kart Parts - Cheap Prices!
V Belt Clutch
Belt Drive Go Kart
If you want to use a belt drive on your cart, this is the solution. This heavy-duty clutch is designed for go-karts.
It is a centrifugal clutch which engages a V-belt. Made in the U.S.A. by Hoffco-Comet.
This V-Belt Clutch is a 3/4in. bore with a 7 HP rating. There are other choices at our dealer.
110% Lowest Price Guaranteed!
Belt drive is a little used concept, but could be safer if you're worried about chain breakage.
Take standard v belts.
