Shop Our Other Sprockets
Shop All Our Parts
60 Tooth Sprocket
Mini Bike 60 Tooth Sprocket Mini Chopper
This go kart sprocket is the standard size and chain size for most projects.
The 4-hole bolt pattern mounts to 2 13/16" hubs. Made in U.S.A. Sized for #35 chain pitch. 2in. center hole. Outside diameter: 7 3/8in.
110% Lowest Price Guaranteed!
A 60 tooth sprocket, paired with a standard go kart clutch will turn around 30 MPH flat out.
If you use this sprocket and a 12 tooth clutch, that's the speed you can expect. If you run a torque converter, you can probably go even faster.
This sprocket is usually mounted to a dual flange hub, and then to a band brake hub. Careful using a 4" wheel -- the sprocket is almost as large as the tire.
