If you lost your valve core removal tool or you don’t have one, here’s a super easy homemade solution.
Grab that useless multi size flathead screwdriver bit set and find one that fits your housing. Bigger is better here.
Cut a slot using any means necessary. I used a Dremel cutting disk.
Throw it in the screw driver and use it. Keep it with the set so it’s not lost as easily.
You just used your inner @Master Hack, congratulations!
