Can i use two bearing blocks (for a 20mm shaft) as swing arm mounts?
MoTiJo2023
Yer gonna do it, so just do it! what do ya need us for? You obviously know more than us. We never claimed to be experts anyway.
Not interested in getting into a pissing match!
Ok, i'll build it that way and it will work. im updating when parts arrive.
(I never claimed that you are no experts)
OK, nobody here wishes you ill will or bad luck or even want to see ya fail. You asked, and were given opinions. You desperatly want to prove us wrong, and that would be good.
Denny loves to see us proven wrong. He'll have us confined to the dungeon and bring out the guilotine!
Still, we wish you luck, and keep us posted with your progress.
How can you talk about the pissing match if we’re not going to bring up the second thing with that guy in the place.
This thread is confusing.
Look how long that swing arm is
why don’t you mount the engine on the swing arm.
MoTiJo2023
Yes it is.... this is just drawing, has nothing to do with how the final project.
Engine cant be mounted on swingarm because of where the clutch sits, to align clutch and rear tire sprocket its going to make the engine sit REALLY off center, so a jackshaft is needet.
