supercharger
Sneaks
What about with boost?
I’ll look for that laptop.
Meanwhile just take comfort in knowing that with Boost, these green numbers in the 60% - 80% range will grow to bigger numbers.
100%? Maybe
110% Plausible
120% Feasible
130% Atainable
150% The little engine who could.
200% 5.7L power from 2.0L displacement?
30lbs of boost is like pumping 6L of air through a 2L engine… I think … (2L@45 psi vs 6L@15 psi)
PV = nRT
Is you incorrectly assume temperature stays constant…
If Pressure is tripled (15 psi to 45 psi) in a constant volume (say 212cc) and assume temp stays constant … Then n (number of air particles) has to triple. As you can see as “T” temps go up the “n” has to go down to stay at a given pressure “P”
As physicists, we choose to ignore most things.
A Manco Dingo
Tucson Arizona
100%? Maybe
110% Plausible
120% Feasible
130% Atainable
PV = nRT
question how much bosst can a predator 212 stock engine can take before it blows up
Thepartsguy
the flywheel can’t take much of anything past stock 3,600rpms because the magnet on the flywheel is held on with a screw and glue... (China)
If you intend to run boost seriously your gonna need at least a flywheel.
Thepartsguy
the rpm should not increase much just the hp rises
I’m trying to work this out in my head.. So let’s say 4 pounds of boost.
All before 3,800 rmps that the governor limits the engine to?
What pulleys would you run to spin/overdrive the pump up enough while the engine is only spinning 3,800rpm’s? And if you remove the governor to get more engine speed that makes spinning the pump up easier but the magnet is held on by glue!
I’m just pointing out (I can’t find The post) someone was saying something about a 2” pump pulley and a 32” crank pulley?
A Manco Dingo
Tucson Arizona
:idea2: remove the governor
Positive displacement pumps make same amount of boost at 2500 RPM as they make at 6500 RPM. It’s a positive displacement pump (roots blower). It’s not a turbo; not a centrifugal supercharger. It pumps a set amount of air per revolution based on pump displacement and pulley ratio. The boost is based on engine displacement, pulley ratio, and pump displacement. RPM falls out of the equation.
A Manco Dingo
Tucson Arizona
but to much rpm and to big of a pulley is to much boost and it will blow up the engine rpm is part of the equation because there is perfect balance between rpm and pulley size to get the right amount of boost I plan on testing and experimenting this theory because to little and the engine will bog down and to much and you know what happens
A Manco Dingo
Tucson Arizona
question you know the leaf blowers that are battery powered and look like centrifugal superchargers
1709924873003.png<----- like this one
well I wonder if you put that on the intake and turn it on and a drops of more fuel into the engine will it either
A-blow up
B-BLOW up
C-BLOW UP
D-HP increase
but to much rpm and to big of a pulley is to much boost and it will blow up the engine rpm is part of the equation because there is perfect balance between rpm and pulley size to get the right amount of boost.
No.
Maybe you misunderstood.
I said RPM falls out of the equation.
You added it back in.
212cc per 2 revolution of crankshaft.
106cc per revolution of crankshaft.
300 cc per 1 revolution blower.
300cc / 106cc = 2.83
2.83 * 14.7psi = 41.6psi
41.6 - 14.7 = 26.9 psi boost (if 1:1 pulley ratio)
Volumetric efficiency doesn’t matter as much when forcing induction.
And as you can see, the amount of air pumped by the roots blower per revolution stuffed into a fixed displacement engine doesn’t change with rpm.
One turn of the crankshaft will always pump the same amount from the blower (depending on pulley ratio). Boost won’t increase with rpm. 212cc eats 106cc of air per crank revolution at 100% volumetric efficiency. It eats the same amount of air 2500 as it does at 6500 RPM… 106cc per revolution.
maybe you can explain why it is that you added rpm back in? How does the amount of air pumped by the blower per revolution change. It is literally named 300 because it pumps 300cc per revolution. How does the rpm change the displacement of the engine? Engine displacement is constant, blower displacement is constant, pulley ratio is constant, boost is constant, rpm can be anything. It falls out of the maths.
A engine with More rpm requires more air per minute, not more air per revolution.
A blower with more rpm pumps more air per minute, not more air per revolution.
A Manco Dingo
Tucson Arizona
No.
K
Thepartsguy
So mike clements did not build this. It was built by Justin W youtube channel.. You can see a whole slideshow on his channel along with a short run of the engine before he sold it to the mike clements museum.
EXTREMELY easy to copy.. Instead of that intricate Tilly bracket why not just Slip the pwk boot on the inlet of the pump and tighten the clamp. Then put the pwk carburetor in the boot and tighten the clamp. Run a tube from the outlet to the pump to the engine intake port like shown.
I know exactly the model of pump he used and where to get 3 of them.. I will at one point be making a cheap copy with my own flare to it..
4406385B-FB40-4F2C-8504-D8DD88B8DDF4.jpeg4D18A2ED-5889-45E9-951C-18E5E0283152.png4A05B4F1-A7B9-4629-84EE-3D9142FB1D1C.png217DBDDF-E602-4DBB-9EF9-1528CCEC9D31.jpeg
A Manco Dingo
Tucson Arizona
question would it be better for the supercharger pulley to mount to the fly wheel or the torque converter? i am buying the parts i am getting the carburetor you recommended and a AMR 300 supercharger and some other small things
