So it begins....
clueless8169
Finished putting on a "stage one" kinda kit tonight. Also took off the red coleman plastic trim and painted it purple. Looks sweet.
12" 3000 lumen amber/white combo LED up top powered off a 12v amazon battery. Next project is going to be a charging flywheel and all that stuff so i can keep my battery juicy, but i know nothing about this kinda stuff so its a learning process haha
Most fun ive ever had burning a hole in my pocket.
Hope you don't roll that thing over... that light bar will be gone. Personally I'd have it inverted so the light so it is below cage level, one less thing busted should she ever play dead.
I might have an unfair advantage 😁
clueless8169
Oh mannn that looks sweeeet how much amperage does that put out?!?!?
Never got an exact read on the amps, but it made 120vAC no problem unregulated and that wasn't even peak but it wasn't stable.
I revised it to bring the voltage down, and the amps up, my current one in the same configuration is pushing around 40A. Once the engine is started it will run everything without the battery.
