Summuns gunna git hurt!
Are you welding with Flux-core arc welding? It helps me to play around with the wire feed and voltage settings first until it works like a hot glue gun, melting both sides togetherWill do.
and clamp things together with an old clampAre you welding with Flux-core arc welding? It helps me to play around with the wire feed and voltage settings first until it works like a hot glue gun, melting both sides together
Yes I am using a flux core welderAre you welding with Flux-core arc welding? It helps me to play around with the wire feed and voltage settings first until it works like a hot glue gun, melting both sides together
When welding steel, I found that it acts like water and draw together when its liquid. I make a pool of molten metal and let it cool slowly. If it cools fast it cracksYes I am using a flux core welder
What welder (brand/name) is itYes I am using a flux core welder
Its the cheapo 100$ Chicago Electric Flux Wire one from harbor freight.What welder (brand/name) is it
Practice makes perfect, keep going, but pay attention to the old guys. They survived. The ones who did something dumb cant tell you. Grind off coatings, make solid contact with your ground clamp, and work in a well-lit, well-ventilated area. wear protective clothing, and don't work tired or drunk.Yes I am using a flux core welder
I use the $149 titanium flux core welder its perfect for welding frames and rollcagesIts the cheapo 100$ Chicago Electric Flux Wire one from harbor freight.
Ima going to have to write that one downOh. Don't work drunk. I'll have to remember that one.
TerrifyingI’ve never worked sober, what’s it like?
