Hi I've had my predator 212 for quite some time, I bought it off some guy on Facebook marketplace place, I know he moded it but not sure what he did exactly but it has always had a terrible kick back for example if I use the original flywheel key way it will almost instantly rip the cord out of my hand, I checked the cam to make sure it didn't skip a tooth which it didn't so recently I adjusted the flywheel and retarded it probably 30 to 40 degrees as shown it the picture, the black dot on the end of the shaft is for something else. And the dot on the inside of the shaft is the key way, Anyways I really don't understand why I have to retard it so much In order to work, so I figured something was wrong and put it back to normal setting and went to my valve set up, I set my valve lash to 0 or maybe slightly past 0 like -.001 for exhuast and am not entirely sure if that ok or if it will burn a valve, but with this lash I can at least turn the motor over by hand while still feeling some compression. If anybody knows why my motor is so dumb please tell me thanks I'm getting frustrated.
