okey i thought something like this would happen yes, also a question if peak/pulse power of the motor is 15kw that shouldnt damage the battery thats rated 3-3,5kw power motor? i mean its just al pulse for like few seconds or a bit more but only counts the continuous power right?Howdy &
If you're talking about a Lithium battery pack
...& "if" it has a built in BMS rated for use with 3kW - 3.5kW
...then, your 4kW motor may try draw too much current & overheat &/or damage the BMS
OP would be able to limit the draw from battery with the speed controller wouldn't he??Well, if the battery pack is 48V & rated for use with a 3,000W motor, the draw would be ~62A (3,000W/48V=~62.5A)
...so, the const draw would probably ~40A
...& peak draw would probably be ~80A
For comparison a 14kW (peak) motor could easily draw anywhere from ~100A - 300A (14,000W/48V=~291A)
...which is WAY over the capabilities of a battery pack designed for use with a ~3kW motor
Yup, a user can set the current limits on the higher end speed controllersOP would be able to limit the draw from battery with the speed controller wouldn't he??
I guess it depends on which speed controller is used??
