break problem
denny4denny
union mo.
Where can i see a video or pic of a break pad install on rear of crossfire .i cant find any direct info on the clip that holds one of the pads in place i did not see it before it fell on the floor. itsthe only thing holding up this job. the front calipers look a bit different or i would pull one them and look? Thanks denny
denny4denny
union mo.
here are some pic of the clip
Why do you keep thanking me? There’s no need for it! Look for any parks on the sides of the pad where it may have clipped on. Just probably an anti rattle clip. One more thing it’s brake by the way.
denny4denny
union mo.
thanks Denny AND also the spelling lesson. i never thought about it being for anti rattle but now that you say that the pads cant fall out they both have two bolts running thru them.I well know in a sec.
denny4denny
union mo.
update Denny after looking at that clip thinking its job was to stop noise it was easy see to where it had to go. their was a spot above the pads where it fix just right and press against the top of the pads. imnot going to thank you this time but my go kart does thank you .it was tired of all the new names it was being called..
denny4denny
union mo.
And all it will cost you is 1 video of you tearing up your yard making you’re kids cry because you won’t let them ride it. :sifone: :thumbsup: :lolgoku: :popcorn:
i got a video of my son and grandson tearing up the back yard ;helping me brake the motor in a couple weeks ago.
denny4denny
union mo.
the another one i just put it in the garage. im going ahead and start working it while the first is waiting on parts to show up.looks like right now it will be Saturday or Monday. it runs great it just not charging at the moment. this second kart is a hammerhead twister. i was told some kids rolled on its side and instead of shutting it off they just let it run untill it stoped.and its been setting outside around 5 yrs. i got the motor unstuck a couple weeks ago.and fixed the brakes.put on new tires. thats all i have done so far its missing a lot of parts.i ll take some pics and post.
