Evanguy
I'm building a Honda gx200 clone, using a flat top wiseco piston at 0 deck height.
Valves are stock size 25/27 I may upgrade them but shouldn't effect PTV in the non hemi.
I'm looking at getting a custom cam from "smallenginecams" .
What is the max lift reasonable for one of these motors. I know duration effects PTV more then lift but is .380" lift with ratio rockers reasonable?
I'm thinking the .380" 256 duration 104 lsa. I also plan to use forced induction hence the cam choice
