Cheap aluminum flywheels from Amazon
busted_blocks
Dongguan, China
I have a bit of experience with these flywheels so I thought I'd share that. I'm not saying use or don't use them.
Here is an example of what I mean. Should be lots of sellers with the same thing
It's a cast aluminum flywheel for Honda GXV160. The ones on Amazon have the logo from the casting company ground off. I have some without, here is what the logo looks like. Anyone have an idea what company it is? Why bother grinding it off? I can't find them....
If you are in China they can be found on Taobao for pretty cheap.
the taper fits the Honda GX200 but the flywheel has a bump at the end you need to drill or grind off. Otherwise it won't seat on the crankshaft.
What I don't know 100% for sure is the timing but GXV160 info online says 20 degrees BTDC. Both of these sites list the stock timing for the GXV160 as 20deg BTC
I have trouble removing these flywheels without damaging them. Any ideas of a good way to remove them? Prying and hitting the crank dents the flywheel.
BrownStainRacing
They are every where over here in the states. $35-$60.
This engine comes with that flywheel.
They say its 18* btdc with stock key.
I jus posted about removing that flywheel on the mini bike site the other day. I'm not a fan of it, jus for that reason.
I do alot of selling, trading, and building. I don't feel comfortable pulling that flywheel off and using it on another crank or selling it to somebody.
I'd much rather use it on 1 crank then be done with it.
A PVL or ARC, I can reuse many times over, as long as the taper and key way is good. I don't use keys.
