Darren
Electronic ignition requires a reference point, trigger wheels (60-2) allow the computer to accurately configure timing
1) the correct position of TDC from the missing teeth 2) the precise measurement of the engine revving up and down, measuring the time difference between each tooth, we're talking milliseconds here. 30-1 is considered the minimum acceptable working resolution, my kit car is 120-2 because it's on the flywheel.
Basic electronic ignition can use a single point reference i.e. a magnetic pick up sensor, I watched the first video and didn't observe where the timing curve was programmed, is this predetermined? Ali express can supply an EFI kit that uses a magnetic pickup, I was going to purchase it until a detailed video highlighted it's drawbacks, one being a single trigger through 360degrees rotation.
Electronic ignition has several advantages over the basic magnetic coil, one being the strength of the spark, second the timing curve if it can be programmed.
The Speeduino works with tuner studio and is fully configurable, this is what I will be using on my build. I will be able to set my 'start up' timing to.. say 10degrees btdc, this may negate the need for a compression relief on the cam.
If the CDi is indeed programmable, being able to set it at 10degrees for start would be a great advantage.
I'll be watching this thread with interest
