This started with with a youtube video, and me carelessly stating "hey son, look at this go kart buggy thing this guy built, I bet we could build that..."
Fast forward a year and a 9 year old doesn't forget. It turned into "Dad, I thought you said we were building a go kart"
So, in order to not be "that dad", I'm building a grand daddy for my 9 year old (okay, it is a bit for me too... maybe more than a bit).
The Grand Daddy plans showed good promise, but.... after getting part way through them I've learned that one should plan on mods, and planning on adapting. It is funny how intricate some of the cuts and details are, yet some parts are "just make this one fit".
Either way, it was a good start. I originally built the base exact to plans, but after placing the seats in and seeing how I would fit (which was not at all), I opted to stretch it 6". I'm 5'11", with an appropriate beer gut, but I'm just built thick at 250. It would have fit my son fine, but only with the seats all the way back. At 9 he is 4'10", and the doc says statistically he'll be 6'2". I'd like this to last him well into his teen years.
I knew I already had the the rest of the corners joints set perfect for a very square frame, and I didn't want to mess that up, so rather than remove the long side rails, I cut and spliced the frame with 6" lengths. I telescoped a piece of 1" on each side, then plug welded it on the outside and bottom, and also added a piece of 3/4" angle on the inside which will make a nice spot to secure the floor when added.
I've purchased just about everything needed... most of the weldments, axle, hubs (i went with 3/4" shaft hubs, with tapered bearings), front shocks, engine, etc... many of the parts came from BMI carts. I'm in way more money than I expected, so, to anyone considering this kind of a thing for the first time - it isn't cheap, but it is fun.
I also ended up extending the rear uprights behind the seat 1.5". The original uprights in the plans are 14", so now they are 15.5". The lower rear bar limited how far back the seats could adjust, and I wanted all of the range out that I could get. Also, rough measurements of the predator 420 showed the "jog" (intended to clear the fuel tank) might still hit the tank.
Hopefully the angle of that picture doesn't show my more terrible welds.
Running adapters to fit the yamaha bolt patter rims up front (4x156)
21x7-10 tires up front, 20x10-10 rear.
