looking for 5 horse flathead cams
Thepartsguy
There’s a bit more to it then just buying them. A lot of them come with no box and you send it to dynocams to get the specs. Next would be the lifter bore area. if it’s not welded no bigger then a 93ss hotstock cam is recommended. Last they sell +.100 lifters for the camshafts with a ground down base circle. And very rarely will some spring packets need cut. Just be carful you get a hotstock camshaft unless you wanna do a small bit of work.DDEE0D5A-9B02-4EA2-BE64-625BD7480E3E.png925090FE-EE17-4D79-B5F8-97BE3DD7C03F.png
Thepartsguy
These are two different camshafts for a 5hp I made. The top picture is a hotstock cam I have run for some time now without trouble. I will get a junk block someday to test my bootleg 112 alt in the second picture.. lobes look like thumbs on the real 112‘s74B08199-D6D5-45D2-A2AF-28847EC12A5B.jpeg43CAAE8B-C202-42FD-98E4-D1EAD6F78143.jpeg
karl
North east Ohio
Are these of interest?
karl
North east Ohio
Need is a subjective term lol
Thepartsguy
ok I’m clueless past hot stock fun backyard style stuff. is that just a gp966 spring kit from dynocams? I don’t see spring pockets cut? Did you weld up the lifter bore? I guess my last question is are those +100 lifters or just stock? One more what cams are those?
Thepartsguy
Please correct me I’m sire I’m wrong did you just machine the lifer area down so lifter taper doesn’t snap it off? I guess I’m trying to learn. And for the above comment the exhaust area doesn’t look welded? The lift on that cam and everyone saying machine work NEEDS done to run a cam like that?54012312-C683-4AE4-BF22-02BCB92321FD.jpeg
karl
North east Ohio
Please correct me I’m sire I’m wrong did you just machine the lifer area down so lifter taper doesn’t snap it off? I guess I’m trying to learn. And for the above comment the exhaust area doesn’t look welded? The lift on that cam and everyone saying machine work NEEDS done to run a cam like that?View attachment 144101
Thats how the shop put it together back in the day
