h3re4fball
So, a lot of you saw my post about picking up the Quantum 7150 for $150 a little over a week ago. After some digging into the wiring and missing pieces, putting on a new carb, CDI, spark plug and a few other little things, I was able to start it! I had not yet gotten my ignition cylinder in the mail, so I broke the original one so I could turn it and get power, and then jumped the starter solenoid to get it to turn on.
After running the cart for a few minutes, I shut it down and was hanging out in the garage for a few minutes when the starter just started engaging again and wouldnt shut off. The "key" (screwdriver) was off, both kill switches were off, and I even pulled the spark plug boot and it was still firing. So, I disconnected the battery and called it a night.
Well, yesterday my new ignition cylinder came in, which is what I originally thought my problem was. I installed it, turned the key, and the buggy still didnt crank off of key power. Whats up with that? Eager to drive it for the first time, I jumped the solenoid again, and took it around the yard quick - it did randomly die right after I took off, but I jumped it again and it did ok - even got to tear up my grass with a couple of donuts! I pulled it back into my garage, shut her down, and lo-and-behold there it was trying to crank over again. What in the world is happening!
One of the only parts I have not replaced is the starter solenoid - so I have one in the mail and it should be here today. Could that cause the no crank with the key, and could that cause my starter to be part of the living dead?
