Sequoia Electrathon Racer
My original plan was to try-n-bend a section of the caliper backing plate
For attaching, connecting the backing plate to the spindle
...or when the brakes are applied the bracket will rotate around the spindle (NOT GOOD!)
Another view
But now, after thinkin' it thru a bit more, I'm concerned that the bracket may warp
...while trying to bend them "tabs"
So, I came up with a "plan B" (independent "tabs") :thumbsup:
Kinda like this
Found another use for them 1/4" x 20 Allen/button head bolts ;)
I threaded the holes in the brackets
...so, we don't need to add nuts to the back side
After trimmin' the other bracket down a bit, we'll have a (L & R) matchin' pair :sifone:
As a public service, Scrap yard engineers would like to replay the episode of SHCS!
Those bolts that you cuss as ya try to remove them with a stripped off allen wrench are known as Socket Head Cap Secrews.
Whats the difference between a bolt and a SHCS you might ask. Well, I don't know. Go ask google.
What I do know is that they are stronger and tougher than even a grade eight bolt.
The bolt guru once told me to consider them a grade 10.5! that's why they are used in machines a lot. That and they look mo cooler.
I like to use them in the tough spots. I have cantilevered shock mounts on frank and that's an example. Your cantilevered rear axle would be a good candidate for a SHCS. Thats all I know 'bout SHCS'S. Valuable info, worth exactly what it cost ya!
Thats it for SHCS.
Nice bolts finish that off perfectly!
Now ya see what l was trying to’splain about the whole doughnut deal?
Yup, it's pretty "sweet"!
Now that we know (or have a good idea of) overall chassis height (front & rear) we can "set" the Caster angle, of the front spindles
I set an A-frame on a level surface
...double checked with an angle gauge
Then, adjusted the spindle bracket to ~5* negative (toward the rear)
* It looks a bit "off"
...but, that is due to the camera angle
Yup, that's more like it :thumbsup:
...& then, couple of "tacs" to "lock" 'er in place
Double checked the setting
...then, removed the adjusting "screw"
Here are some pics of the hub mounted on a spindle
Top view
Here is a wheel mounted on a hub
...which is mounted on a spindle
...which is mounted on an A-frame
...which is then, mounted on the chassis
Top view
* It's a bit outta focus
...but, it still "shows" the caliper to wheel clearance
The wheel actually fits?
How did THAT happen?
You might notice the rear brake rotor is warped a little. I don't think it will cause a problem, but you might need the 娜吉艾哦 dewarping tool. I found the rotor to be "flexible" might be a good term.
Hey T,
Yup, I noticed that "warpage" while test fittin' the brake caliper, on the rear hub today
Caliper mounted w/M8 buttonhead's
...& notice the bleeder screw is toward the top ;)
Also, the adjustable sprocket/rotor "carrier' came in handy :2guns:
...as I needed to adjust the rotor, inwards, toward the caliper ~1/32" for optimal rotor to caliper alignment :cheers2:
Good clearance Clarance!
Het Denny,
The hub to caliper clearance seems ta be "tight" but, adequate in the rear as well :bannana:
nobled2
Hey T,
Het Denny,
My kart is not in this level of building but I found that if I leave the rotor to float while keeping it attached to the axle with a simple keyway, it keep unwanted rubbing and friction to a minimum.
Hey nobled2,
Interesting tip
...& thanks for sharing :cheers2:
There doesn't seem like there is gonna be much room for a dashboard
...so, I was thinkin' something like this :thumbsup:
Maybe/kinda like this
Another view
