Tire tool?
pearl111
Baltimore, Maryland
Has anyone ever used this tire changer before?
How well do this work.
I have a Harbor Freight tire changer that works ok. Sometimes not, just looking for something a little better, without spending a lot of money.
Or any other suggestions on a decent changer at a good price?
Thanks
Thepartsguy
I don’t have a better method or anything helpful but I would love to have a tire changer at all.. I set a 2x4 on the tire drive Onto it. Just don’t smash the rim.
You lay a 2x4 on the sidewall of the tire and drive a car up on it to break the bead. People have been doing it now for over 5 years since the pneumatic tire was invented over a 130 years ago and the car too!
karl
North east Ohio
All you need. Once you get the technique down, there not much point in having a changer for small tires.
Snaker
Thanks
Is your present changer one of these?
Mini-Tire Changer (harborfreight.com)
Manual Tire Changer (harborfreight.com)
One is for smaller tires and one is for full size tires
I've had both and it really doesn't get any easier short of commercial
pearl111
Baltimore, Maryland
Are those pipe/adjustable wrench handles? They look like they would be better than the heavy long handled screw drivers that I use.
pearl111
Baltimore, Maryland
Snaker
Don't know what to tell ya.
The reason I got that one is that I was doing a lot of those small wheels 4-5"
They're the worst.
They are just big enough that the mfgs decided to not make them as 2 piece bolt-togethers.
But are a challenge to pry off
The thing works like butter for me, and I've done some cringey wheels.
The larger wheelbarrow wheels are a chinch.
Don't know if yours is defective or you have bad technique or lack of practice?
A spray bottle of dish soap / water is a necessity.
Bansil
Painter of gnomes....
They're the worst.
Have to agree the harbor freight one does work, you need lube like said, soapy water is great
ETA I had one in between those sizes it was made for atv tires, they may not have it any more
2 piece kart rims make tire changes infinitely simpler and effortless...
I do motorcycle tires by hand with nothing other than a set of 3 steel bicycle tire levers....and yes I've managed to bend them a little by getting the last bit of bead into seat.
