go kart plans
DIY Go Karts
Buy Great Go Kart Parts - Cheap Prices!
Folding Foot Pegs
Great for Mini Bikes and Mini Choppers
Pair of foot pegs fold when not in use. Long mounting studs and sturdy rubber treads. Clamps attach to 7/8in. diameter frame tubing.
110% Lowest Price Guaranteed!
Make sure you're getting the right size mounting pegs. These mount to 7/8" OD tubing.
You could also use these pegs if you were making a two seater mini bike, or a long chopper. They would fold up when the second rider wasn't on the bike.
The pegs are made to mount to tubing without drilling holes. For non-welders, this is a great accessory. No drilling, no welding, no problem! The only trick will be to make your frame from the right material. Already made a frame that's thicker? You can still use the pegs, either by welding them on, or by fabricating your own mounting straps.
