Hey T,There seems to be a discrepancy between the measurement called out (1.37) and what you measured (1.392).
Assuming the odd ball bearing fit (34.925MM) the measurement must be closer to 35 MM (1.378).
What I'm getting at is, The common kart front wheel bearing (99502H) is .625 X 1.375 (5/8 x 1 3/8).
Another alternative is a 6202 -10 (5/8 x 35MM)
One might fit better (OD) than the other....
Yeah its only .003 but loose is no bueno.
Probably my measurement skills. I guess, I need more practice
Speaking of discrepancies, when I Googled the 99502H I found
99502H NR - Radial Ball Bearing with Snap Ring (10 pieces) (~$23.00)
(16 mm x 35 mm x 11 mm with SNAP RING)
(5/8" x 1-3/8" x 7/16" with snap ring)
https://www.ebay.com/itm/2715678288...044&customid=c8af45d18a401a62480a20afe96d31f4
& I also found
Go Kart seal bearing Snap Ring bearings 99502H NR 5/8 X 1-3/8 (10 pieces) (~$19.00)
D (Outside) | 34.925 mm |
d (Inside) Bore | 15.875 mm |
B (Width) | 11 mm |
%252BdwgqvPWYUaZsVvEChsC5iN7aH42t9t6m7pqFbm7YB0QWI%252BHfUEVpiv5TVj4qz%252B6bslgPe3gS0BJgTHK%252Byv8g9y8t2EGR3%252F3jvPUtN%252BFd4PUBA6YuV5MhiNBGRqfuVsrw%252F6H9W1OHkKVP9R3%252B%252Ffo%252FfGylxZxtBWtrIqMCr4HISKbpdVpUhVBpFafOZO
62s3rKxcGuSdJBRWucLLNztOqziSAOfgPpQLNjLnwdZHNrEbQlqDd2fO6DsdGFT6x%252F%252F6eI2ZcK5ulnNVbEKVN28wnkH%252FSA%253D%2
53D%7Campid%3APL_CLK%7Cclp%3A4429486&epid=530557915
So, the specs for the first 99502H bearings are listed as 16mm x 35mm x 11mm
...& the specs for the second 99502H bearings are listed as 15.875mm x 34.925mm x 11mm
Ya think the specs of them first bearings, were just "rounded off" for us stupid Americans?
IMO It looks like the snap ring, may be a way that some manufacturers used to add a "lip" or flange, to standard bearings
