Try it out stock the way it is now. It's gonna surprise you.
When the box stockers run Ducars with the predators, they have to turn the Ducar DOWN to 5000 rpm, and turn the predator UP to 5000 rpm.
That right there should tell you, it's ALOT better build engine. It's got all the right parts combo to get it done and last.
If i was you, I would leave it the way it is, and run it, test it and you will see how it performs in stock form.
Box stockers can only change the main jet in the carb, usally way too freaking rich for up/down throttle, they dont worry about the low side, since even under a yellow flag they have the engine up on the cam and right in the powerband, jus waiting on the green to come back out.
I bet if you look, it's still got the stock .045" thick head gasket on it.
The only thing it really needs is a .018"- .024" head gasket. The piston is setting .010" - .015" in the hole at TDC, so a 18-24 thou gasket would be perfectly fine and get the CR up to around 9:1, I'd have to do the math, but 9:1 sounds bout right, with that dished piston and 20-21cc hemi head, I forget the exact cc, but it's not 22 like the pred hemi head.
Install a short header 6-8" long, .880-.890" ID, with a open muffler.
Mild port work in the head, the valves dont need unshrouding, it's a hemi,
2800-3000 rpm stall springs in the driver
Add a good bored SA carb from Dover or RPQ, and you won't need a 6:1 gear.
Maybe this weekend, I'll throw that .675" RPQ carb on this 212, and see if it'll yank up outta the hole, and jump slidewayz from a dead stop,
